Inconsistent boost
typhoon1588
Right now I have no way of getting a hold of a Datamaster setup, hopefully someone in NASTE has one and can run it with me at the next meet.
Anyways, my boost is inconsistent as hell. And I know it's know because the gauge is inaccurate, it definitely feels off at times. I can't figure it out, it's like I'll get in the truck to drive to work (a whole mile away), and whether under steady gas or WOT it will only build about 9-10 lbs. of boost. Six hours later I will head back home and the thing will hit 14.7 every time. And then there are times I will apply even pressure and build 14.7psi, and a few minutes later do the same thing and only build like 8 lbs.
Is this the turbo going sour, a wastegate problem, or what? The truck only has some 52,000 miles on it, and most of which are unabused higway miles between NJ and Rochester NY.
Thanks in advance for any help.
jwaller
Evil Genius/SyTy Guru
if your only driving it a mile it's not having a chance to warm up all the way and probably not getting into closed loop mode. this could explain your not seeing full boost.
Phoon30
Mike, next time we have a meet I'll bring my Datamaster. Have ya checked all your vaccum lines?
typhoon1588
What's the best way to check it out to make sure that that's the problem before spending money replacing it?
And jwaller, that wouldn't make sense, because of its inconsistency. Sometimes it will sit for a day and when I go to drive it it won't get all the way there, other times it will be in freezing weather for a week and run a full 2 Bar when I accelerate.
Thanks for the help, and thanks for the Datamaster offer, which I'll definitely take you up on Mike.
mike
p.s. ron jeremy scares me
Daron
Inconsistent boost can have many causes. Miss Cleo may try and pick just one, but that is because she is psychic.
Understanding your boost control system will help you troubleshoot your problem. Brian Green has a great explanation of boost control somewhere around (Link anyone?).
One of the most common causes of boost issues is knock. Get over about 6 degrees of retard and the ecm begins to remove boost (as far as I remember). Getting the truck on the scan tool will tell you if the ecm is commanding the boost reduction, and eliminate most other mechanical causes. For instance, I wouldn't go and replace the boost control solenoid until I had addressed the more common causes of your problem, and eliminated the possibility that the ECM is commanding the boost changes.
A sticky wastegate can cause boost control problems and has been addressed here before.
Old brittle vacuum lines are notorious for cracking and can leak during boost, yet be fine under vacuum. Replace all the rubber elbows under your hood if you haven't done so already.
Some have boost control problems with a free flowing exhaust (read "no cat").
So, please approach the problem by identifying possible causes, then work on the most common failure points to the least common.
Good luck,
smeagol
Warren did that for me way back in the day.. I didn't know that page was still up.
I'll probably post an updated boost control page soon.
kwick6
Lots of good info out there. I really like the idea of getting this stuff organized. It would be nice to have a FAQ with a search feature...sorta like the archives.
Scott
