Injector cap issue
Anyone ever have their injector caps fall off in their intake?. Went to change my injectors and found two of them missing caps.
0966Sy
Code what?
I've seen them commonly cracked but not actually fall off inside while removing them. Although it is possible. Best thing I could suggest is bringing each suspected cylinder to TDC and use a vacuum source on the injector port while blowing compressed air through the spark plug hole. That would give the best chance of recovering the debris if any from the tops.
You could use a bore scope to confirm any pieces in the cylinder. Worst case they would melt and pass, not causing as damage like a piece of metal or liquid
Re: Injector cap issue
Thanks for the fast response, i used my scope to go in and look didn't see anything the motor has 155k on it. When i pulled them out they were definitely original just them two were missing. I kinda figured they may break or burn off just kinda nervous as to causing damage never had that happen. Ill give the vacuum a try i guess, thanks again.
0966Sy
Code what?
Injector cap issue
I'd put money on those being long gone already.
More than likely yes, but it would be possible for them to fall off during removal for sure. I've had them fall off after removing them. But like I said, they would more than likely not damage a valve
I was shooting for them being long gone already haha. I just replaced them with 60lb ones, Im kinda changing my setup just bought a bigger turbo and few goodies. Im mad, i had ordered a turbo tweak for my old setup then found a steal on a pte turbo a week after i got the new tune. Going to have to get that redone and find a deal on a converter now.
