Injector driver mod
Ryan Heller
Does anyone do this i just want to be able to send my computer to some on and have it done i do not want nothing to do with doing it my self
Thank you
Ryan
berzerker
wookie
Re: Injector driver mod
have you purchased the drivers ? search for the printable instructions here , long post about 10 tears ago .
if you have the drivers already in hand take the ecm and the instructions to a tv repair shop and explain what you need done and show the instructions . cost me $25 . thats what i did and have not any issues with the ecm in over five years .
STOUT74
Nolan up at Campbell Automotive modded my ECU for low-z injectors. Don't know if he still does, you may want to give them a call (780)452-3535.
skwayb
NWSTP
Ryan,
Why do you need the injector driver mod? You running Low Imp. Injectors? Are you going to run them P&H? If so you need to change a couple of pins at the ECM Harness for Peak and Hold and if it is for a V6, you need to change the sense resistor so it can run them in Peak and Hold. There is a post on www.code59.org with the info on the injecotr driver mod, wire changes and sense resistor change. I think it is in the FAQ Section,
