Injector drivers and twin TBI
JoeLutz
I am working on a twin 2bbl TBI project for a streetrod. They will be fueling a big block with a 6-71 blower. I was wondering if the common injector driver upgrade for p&h injectors would be a sufficient upgrade to control the 4 low impedance TBI injectors split in two batches.
(Fairchild Semiconductor HUFA76429P3)
I am planning to use the 749 ecm but am open to suggestions. The reason for the twin TBI's instead of pfi is we are going for a more nostalgic look of twin carbs on a blower.
TIA
z28camaro
The 749 is already setup to run 4 P&H injectors from the factory. The early quad 4 cars that it came in used 4 P&H injectors, so you shouldn't have to modify the drivers. You might have to wire the injectors diff. though. Try looking at a 749 quad 4 wiring diagram to see if it is diff. from the syty wiring.
