INJECTOR DRIVERS
ed89
I have been working on converting my 89 vet to the 7749 ecm. Does anynody know if the Fairchild HUFA76429P3(the ones Leroy used) will hold up to running 8 Ford SVO P&H injectors? Or how do I go about calculating if they will hold up?
Thanks
Ed
leroy
The drivers should work okay. I think they are rated at 44 amps.
To make sure, the guy to talk to is Gorden Jennings. I could not have figure this out without Mike V's and Gorden's help. All credit goes to them.
Jim
ed89
Jim
Thanks for your Reply. You are corect I went to Fairchild and pulled the specs, the drivers are 44A, 60V, .025 Ohms. Hopefully Mike V and Gorden Jennings both see this post and can confirm that it is enough. Thanks for the information on the drivers.
Best Regards,
Ed
