injector duty cycle over 100%?
SikVSix
Ok,
so I finally got my DM working today, and one of the 1st things I wanted to look at was the injectors as I thought the stockers may be coming up short. The truck seems to have a built in rev limiter around 4200 rpm ( varies some).
Sure enough the duty cycle is high and keep in mind I've never seen DM files before but how can the DC be over 100%? On a 1/4mi type run, the cycle stayed around 95-120% with a few dips that I couldnt explain unless its just a bad spot in the file or something. also had plenty of spark retard, think it was up to 8 if i remember right, trying to remember too much info here.
So I guess its obvious I need injectors but now I'm wondering if 50's will be enough, or should I go ahead with 75's or something as I plan to add alky soon and heads etc later.
Here's what I have now;
-all stock long block
-PTE 51
-manual valve running around 17psi
-3 bar
-custom chip ? ( all I know is its set up for the 17psi )
-ATR 3" DP- no cat
-K&N to Cobra head pipe
-walbro 255
-AFPR (40 at vacuum, up to about 60 @ full boost)
-stock injectors
-hot wired jasbro ic pump
-2800 stall in a nice tranny
thats most of the important stufff I can think of
I guess another thing I'm wondering is if the injectors are maxed out, why hasnt it leaned out and destroyed some stuff, is the ECM smart enough to keep it from self destructing?
any adivse is appreciated
Sean
TYTILIDIE
METH HEAD
Re: injector duty cycle over 100%?
I would imagine that stock injectors are way small for a PTE52. Otherwise, it sounds like your truck runs kinda like mine when it comes to the INJDC. One thing I can tell you is that the "redv limiter" is not set @ 4200 RPM its just when these trucks are setup to shift. Wish I could help you more on the INJ deal I know its had me stumped as well for a while now. I have new ones to put on my new build so maybe Ill be able to give you some feedback when I get her running.
SikVSix
cool,
yeah let me know how the inj work on your new build when time comes, what size did you get ?
on the "rev limiter" I wasnt real clear, I know it doesnt have one, it just seems like it gets up there real quick and then hits a wall for a couple seconds before it shifts... feels like its either running out of gas or weak valve springs or something like that, those are my guesses anyway. probably a combination of everything after the turbo being stock.
It doesn't surprise me the duty cycle is over 100%, pretty much over 95% the injector is open all the way anyways. Some of the stronger stock turbo will peg the duty cycle over 100%. The most I have seen from stock injectors is 114mph (Sy) and 112 (Ty) You could up the fuel pressue to help compensate (higher fuel pressure makes the injector act bigger) Anyways your PTE51 probably could benefit from a bigger injectors.
qbnkiller
Conflaguration Specialist
The 50's might be on the edge for you when you crank on it. I'd almost do the ECM mod for lo-impedance injectors and then do the 75#ers. PM me and I can fill you in a bit more on the who/what/where/when/why's.
Go with the new 65# and avoid ecm mod. Will require custom chip but what truck doesn't anyways?
SikVSix
sounds like a happy medium there, the truck already has a custom chip although I know nothing about it. Is it any easier to modify the same one if I can find out who did it first, or better just to start from scratch ? I'm still feeling my way around with the computer tuning here. This is Scott G's old ty if anyone knows who chipped it.. better yet, I need to email him anyway.
thanks
Captain Morgan
Moderated User
I ran my stockers to 132% DC with my PTE-52 :lol:
infact, its been my best run to date, havent been about to come close with the 50#ers in the truck, lol
SikVSix
wow, thats kinda interesting!! what's the deal with the 50#ers, just need more tuning or what ?? also curious about what the DC is now with them in.
I was also wondering about the high INJ DC i was seeing on my truck, i have lucas 33lb disk injectors but they are essentially the same size as stock and im running 52 PSI static(no vac) pressure, and im seeing high 120's DC at WOT on an 1/8 mile run.
Should i raise my PSI or buy bigger injectors?
