injector PW spikes
SBNova
While datalogging Ive got some injector pulse width spikes that I dont think should be there. On a steady cruise I can see an occasional spike or two, probably every few seconds, up to 20ms from an otherwise steady 3-4 ms. I will have to see if its present on my other logs. I have compared it to my TPS voltage to see if I was initiating a pump shot- but the TPS is steady too.
How can I copy a screen shot from Tunerpro? Ive seen it done but dont know how to do it.
nallj92
Re: injector PW spikes
stock injectors? mine used to do that before swapping injectors to 50lbers, i heard its just a glitch and you shouldnt worry about it. there false readings. I just ignored them. I could be wrong tho.
SBNova
Yeah stock injectors, stock everything other than a hack job 3" cat back exhaust made for the previous owner by some exhaust shop.
I was thinking it may be false, as the 02 mv stay in line (oscillating) and when I had the WB on it I didnt see any fluctuations at cruise. The spikes happen quickly though, short enough to not make much difference but enough to possibly lower my MPG.
2kwik4u
Resident slow guy
Not sure about this, but have you checked it against the EGR....I'm not sure exactly how the code works, but it stands to reason if it's opening the EGR valve it will want a bit more fuel.....Although that seems like a pretty drastic spike.
Just a thought.
SBNova
Actually I have not compared it to the EGR opening, hmmm. I will check that tomorrow when I get home. I do feel that I am having some EGR probs, as was getting a stumble when the EGR opened. Ive nearly tuned out the stumble in my quest for better MPG, but I still plan on taking the EGR off and cleaning it out. I know my TB and upper intake were filthy when I cleaned them last week, so the EGR cant be far behind.
SBNova
Here is a screen shot of some spikes. These are at idle, showing no throttle movement, fairly flat MAP, and a slightly wandering idle.
(To those in the other post, thanks for showing me how to post this shot)
