injector rail
NecroWolf
lost marbles member
i was replacing the o-ring seals on my injectors cause one let loose on the drivers side. looks like it was pinched when put together and now i'm having trouble lining up the injectiors on the fuel rail. i'm doing this without taking the upper intake off. anyone got any input on how to make this easier? i managed to destroy atleast one of the injector seals so far so i gotta pull it back apart. again. is it easier to do it with the the upper intake off?
TurboTony
Re: injector rail
Just take the upper off and save yourself a bunch of grief.
While you have it off clean out the throttle blades and the plenum.
Tony
SY2932
Administrator
Re: injector rail
Might as well port match the upper to the lower while you have it apart...
NecroWolf
lost marbles member
Re: injector rail
well if i'm gonna port match it i might as well drop my l35s on but if it's easier to do it with the upper off i'll pull it thanks guys
blk00z28
Forced to by choice
Re: injector rail
Its alot easier to take the upper off then anything. Make sure you put a small amount of oil on the o-rings too, it'll keep their live longer and be alot easier to get back into the rail/intake. ;)
