Injector size with Stealth Turbo
akty
Just wanted to find out what would be the general consensus on injector size for this turbo. I would like to use 50lb's. Will these be sufficient? I want to stay away from doing the ecm mod for low impedence injectors.
Thanks guys
Windedv6
Ty n 10s
The size of the injectors are going to need to be bigger depending on your boost levels. 50#ers are to small. I am running 75# with my 70 stealth and running 80-90% duty cycle at high boost levels. If you can keep your duty cycles in the 60% to 80% range you will have optimin accuracy and efficiency. You also get some headroom if your program is setup to add extra fuel on boost spikes.
I maxed out my 50#ers with my te63 turbo....
John
tealty
I guess it all depends Pete. If you have stock heads etc...then the 50's will be fine. Back in the day, my typhoon has stock motor and a te45 (similar to a 63e) with headers and the ultimate and 50#chip. I never came close to maxing out the injectors. As a matter of fact, i had to lower base fuel pressure to around 30psi b/c the injectors would be too rich in 3rd/4th gear at WOT and cause the truck to sputter. Even on 28 lbs of boost, the injectors were more than plentifuel ( :lol: ).
later
jordan
akty
Well, I am installing stock vortec heads along with this turbo. It seems to me that when you have more air flow it should be backed up with more fuel flow. Hence the need for bigger injectors ie: 75lbs.
Better to be safe than sorry, correct?
tealty
yeah true for your motor's sake...if you step up to vortec's then definately need bigger injectors if you wanna be really safe. Im not saying the 50's wont work with vortecs and that turbo, but some people like being safer than sorry and some people like living on the edge. Its all up to you.
jordan
