Injector upgrade suggestions, please?
92Ty#1524
My recent DM runs at the track indicated inj dc around 126% with base fuel pressure set at 43 on a stock Ty with 75k miles. O2s were in the mid to low 900s. WbO2 isnt here yet but I'm seriously considering going ahead and upgrading to larger injectors that will never max out with a stock build and have room for some possible future mods (mild cam, turbo and L35 heads).
I'm looking for recommedations for an injector that can give me more performance than stock as well as room to grow. This injector should be paired up with a ready to go aftermarket chip (as you would recommend) or require a chip that can be burned with a compatible time tested program.
I'm sure the answer is here somewhere but I need to commit to a resolution in the next couple days in order to get the parts by the end of the week. and lack the time to do the proper research. I'm leaning toward 50s but am open minded to any suggestions.
Mucho thanx
QUICK STORM
B.A.M.F. BMW Tech
Re: Injector upgrade suggestions, please?
50# or 65# high impedance injectors, so you don't have to mod your ecm for low impedance
Tooky
Serious about performance
My advice is to save your money until you're running mid 12s or better. Mad Mike actually went 11.7 with his stock injector Syclone and race fuel. With the stock injectors you can run the stock injector Ultimate chip which is the most configurable and easy to use "generic performance chip" you can buy. The one for 50# injectors is geared more towards racing.
The stock injectors are good for about 400HP.
If you have the capabilities and/or skills to do custom tuning on your truck, then the 50# PTE/Delphi injector is a popular choice with many tuners already having baseline tunes you can start with.
I wouldn't really trust the datamaster "Inj DC" figure. The wideband will tell the real answer anyhow.
