Injectors and chip
DRUNK411
I have been doing some looking around and trouble shooting on my truck, I am sure some of you have been reading my other thread and I think I might be looking into getting a set of 50# injectors. Those seem to be the common setup on these trucks and a AFPR. My question is this, if I do it I would also need a chip, but is there a chip I can just put in the truck and call it a day? My setup I have now is a Waller 57mm turbo upgrade, rebuilt motor, Walbro 255 and a CAI. Do you think I should go with a set of 50# injectors or stick with stockers for my build I have now. I would like to one day do a bigger turbo, possibly but not anytime soon. Also I have a set of 42# injectors now would these work and does anyone have a chip for them. Thanks in advance.
Trapper
Re: Injectors and chip
With that set-up you have now you could go the route of code$59. Go to Moates.com get an emulator and the sign on with code59 and down load a bin close and autotune from thier with a few logs I can be a pita but its cheeper than a programmed chip from a programmer and if it isn't right, more down time since you have to wait for the chip to get there and back, you cold make your current 42 work too. My truck came with 75s but I think I might go 50 myself just there seems to be more support for that size injector and I'm only shooting for low solid 12s high 11s witch has been done by few on stock injectors and racefuel.
DRUNK411
Yeah I just want a reliable truck that is pretty fast thats all I look for. I probably will be adding alky injection sometime down the road also. So I just want something that will work with all my plans.
SCWolverine
Yeah, what he said, especially with two trucks you could use $59 on. Will ease the transition to spraying alky also. If you plan to keep even one vehicle with a SyTy heart you can't go wrong.
I wonder how many times that statement has been made...sounds reasonable, until you decide you want more, and more, and...lol. It's the beginning of the beginning man, all up hill from here.
fivetodrive
CRISPY
I have all the stuff that you need to go to code$59. I could set you up for about what you would spend on a set of injectors and a chip... WyoSyclone has a very good bin (an electronic chip) for the 40lb injectors. I think that it would be really close to what you would need for the 42lb injectors that you already have. Getting into tuning can be hard but the benefits outweigh the costs and the learning curve.
DRUNK411
fivetodrive, Shoot me a PM on how much it would cost and possibly a little info on this code59? I see it referenced alot but I am not really sure what it is. Thanks
SCWolverine
code59.org
By the time you get through the 10-12 stickies in the Tuning Section all your current questions will be answered (but each one answered will likely generate 2-3 new ones).
