Injectors, Peak & Hold or Saturated.
Hu Ryde
What injectors do we have? What 50lb injector has been proven better than the rest? What base FP is everyone running with the 50lb's?
smeagol
Stock syty injectors are Saturated high impedance injectors.
50lb/hr injectors - the Delphi 50s are the ones most widely known as the 50s (also known as MSD or AC Rochester injectors). They are high impedance, not requiring any ECM/driver modification to run them. Any other 50lb/hr injector is a low impedance type, requiring an aftermarket computer, or driver modification in the stock ECM.
Fuel pressure - the calibrations I worked on were geared around 43.5psi, but you can fine tune your fuel pressure if you like.
_________________
Brian Green
www.chitownsyty.com
syclone160@yahoo.com
<font size=-1>[ This Message was edited by: smeagol on 2002-04-07 10:25 ]</font>
Hu Ryde
So since the MSD injectors don't require a ECM mod then is it required to upgrade the ultimate to get them to run? What is actually changed in the BIN on the Ultimate? Is it a longer pulse or a quicker one, or neither? Thanks for all the info!
leroy
The bin file must be changed. For the most part, pulsewidths are reduced. It's not as simple as reducing the pulsewidth a proportionate amount.... The 50's aren't really accurate at very low pulsewidths, so q-a fueling should be used. Injector reaction times are different. The 50's aren't completely linear. Lots of subtle changes to consider.
smeagol
Lot of changes in the calibration. As Jim said, the 50s aren't completely linear, but they are the best you'll see for a large injector.
Actually I've found the 50s to work well at low pulsewidths, but I've still converted all of my 50# bins to quasiasynch fueling for anyone who knows WTF me and Jim are talking about.
Injectors have their own characteristic, and you don't just toggle a few settings in the chip to account for them. I've spent a few years working on 50lb/hr calibrations, and lots of fine tuning have made them run really well. The stock motor calibrations are running really well, with some WOT tuning necessary.
