Innovate LC-1...anyone using it?
Bill Z
Re: Innovate LC-1...anyone using it?
Looks intresting. Seems like it is only as good as the O2 sensor that you connect it up to. But what do I know?
crashing_sux
Blow Me?
I like it. Seems a damn site better than that big ass box I have in my truck. The whole thing is empty, I really wish it wasn't so big. I was thinking about replacing my fuel pressure guage with a wideband guage. The in cable unit is nice but you still have to have some place to view it. I guess datamaster would work but I like to have it a little more accessable than that.
ashman
I believe it comes with the Bosch WB sensor for $199...$149 without.
leroy
I just bought a new one for $175 on ebay. I'll let you know how it goes.
Jim
I read somewhere that the Bosch O2 sensor needs to be lower than 900 degrees. Is ths true and isour stock o2 sensor usualy below than that temp?
leroy
I think that's 900 C. We should be below that usually. Quite a few people are running the Bosch sensor in other devices successfully.
Jim
I just read the directions on their site.
900 is the body of sensor and not the tip itself. They show in directions how to make a heat shield if you do get the higher temps.
You guys almost have me buying one of these sensors now, be easier than all the wires, etc on my DIY WB box.
93 TY 2185
I've been using the LM-1 with the Bosch O2 sensor in the stock location.
It's been there for 2 years now with no over heating of the sensor problems.
TT350
Manufacturer
I put a Western Motorsports W/B in a customers Buick
and it uses the same sensor. He runs race gas all the time
the sensor will bit the dust after about 10 gal of fuel
is run past it. We put 6 sensors in the car. I was calling
them so much that they where selling me new sensors for
$80.00 shipped to the door from Canada. IMO if you
plan to run race gas stay away!!!!
Chris
leroy
I installed the LC-1 the other day. It took 4 hours, including a trip to the hardware store and about a 10 mile test drive. It appears to be working okay. The price is close to what I spent building the diy-wb, and the sensor replacement is cheaper.
Jim
tyndago
I have used them on other cars. Seems to work fine... and I know someone that works at Innovate...
leroy
windowlicker said:
I guess you have to connect this to a gauge which is sold seperately?
I hooked mine up to the ecm, and use datamaster. It comes with logging software. I haven't tried that.
Jim
ashman
JS Manufacturing said:
I have one and so far it is great tied into stock ecm.
Can you elaborate? Are you using the NB output with the stock ecu?
I am running open loop, so didn't bother hooking up the NB side. I just use dig's hack, into pin F14. Had to load the Innovate software to change the curve. Search on here will pull up screen shots to make it easy to do.
Then on tunerpro I have a dash open for Target AFR. I set mine up with a 12v lighter plug with switch, sensor ground on clip lead, etc so I can move from vehicle to vehicle as I tune different trucks.
