innovate xd-16/lc-1 help
turrrbo6
is anyone having any success with this wbo2 mounted in the stock location. everything works fine and then the screen blanks when boost increases. turn the truck off and back on and I have a reading again and then ditto. thanks, Lee
TYTILIDIE
METH HEAD
Re: innovate xd-16/lc-1 help
Are youre grounds set up ok? Mine works fine but every now and then it kind of flakes out and gives me an E9. That was before I swapped out my ALT. Check your voltage on boost runs.
turrrbo6
yes, my grounds are as instructed. after leaning it out some at boost I finally got an E8 code which means it is getting too hot.
clone 94
i had my exhaust guy put in two sensor bungs in my new down pipe he made for me, one in the stock location and the other a few feet down streem. i wanted it in the stock location for ease of servicing it, but needless to say i had to move it further down streem away from the heat of the turbo. you could also try a heat sink
the LSU4 sensors cant take much heat
turrrbo6
that is going to be my weekend project, thanks
