innovative wide band
11secty
anyone running this. i just bought it today hooked it up and was trying to get some readings .
when the truck warmed up it was reading 10.7-10.9 thats a little lean isnt it
i havnt ran 0-100 on it yet . as most know i have a new motor so all idid today was run it up to 10lbs of boost and it was reading lik12.3 some where iin the low 12s
anyways just trying to figure it out i guess and see what everyone else is doing with it
93 TY 2185
Re: innovative wide band
Make sure you have the software set up for A/F for gasoline.
Some of the LM-1 went out programmed for something other than gas.
Also 10.9 was this at idle? That is way too rich.The low 12’s is an ideal place to be at WOT.
Give us more information on your build and what chip are you using.
11secty
30 over motor eaglerods ross pistons stock cam stock heads a2a intercooler pte 54 turbo walbro fp and fpr 50 lb inj externaly gated mbc and a phil long chip
and yeah i had the whole air fuel thing back wards sorry im use to the el cheapo gauges
skwayb
NWSTP
I don't have a Innovative but it sounds like it is out of calibration. I have the Tech Edge Wbo2 and I have to calibrate the Free Air value so it knows where 14.7 is. So I am sure there is something like that for the Innovative.
11secty
yeah i calibrated it first
11secty
scotts4 said:
why did you go with stock heads and cam with your build ?
coulda woulda shoulda i know that will be the next thingcam and heads, my heads are actually p/p but the next thing will deffinately be a cam then maybe some heads when im bored this winter
Turbo6
10.20@131.8
You should be able to adjust the wot fueling with the different settings on the chip. I sent you a paper with it didnt I? :) It shouldnt be that rich at idle at least I have never seen on that rich with that calibration. Datalog it and send it to me and we'll work on it.
11secty
k thanks alot phil i just have to download the disk in my computer
just had a new baby yesterday morning so the ty has just been sitting in the yard
and i think my fp is still a little high base is at like 46 ishjust got back from the hospital so gonna go drive the truck in a little while oh but i did run it up to 16 lbs the other day man that sucker pulls super hard after it gets to about 10 psi but yeah with the fuel set at +3 15 deg timing i was at 12.3 af never went any higher was kind of hard to watch the gauge and steer at the same time
