installed mini-gate, not venting correctly? 20 psi
cvcsmkr
installed a minigate on the crossover. after blowing about 3 IC connections off i finally got them all tight enough. i wired the stock internal shut. but now the truck will hit 20 psi very easily. the WG is suppose to have a 15 psi spring in it. i had a boostvalve on the vacuum lines. but i just took it off and ran the 2 vacuum lines from the wastegate to a tee then to turbo. so it should be off of base boost. I dont know how loud the wastegate should be so i dont know if its opening at all. As you can see in the pic the outlet of the wastagate is right above the swaybar(about .5") could this be the problem?
thanks for the hosting smaug
leroy
Try pinching off the top hose. It looks like you have equal pressure going to both sides of the diaphragm, hindering movement.
Jim
cvcsmkr
just did some more reseerch after your post and found out im an idiot :p . of course its not going to open unless theres a press. difference. and i was opening the boost valve all the way, where as i should have it closed all the way then back it out from there. thanks
93 TY 2185
Is there really a 15 PSI base spring available for the MiniGate now?
I've been playing with a few springs and can't quite find the right spring rate diameter and length I need.
Typhoon #1133
i talked to PRM last week when i ordered my flanges and he said there is still only 1 spring. he said you may be able to fit a washer in there to give the spring more tention.
cvcsmkr
yes mine has a 15lb spring in it if i run off of base it only hols till about 12psi. if i run the "boost valve" on it all the way closed i get like 19 psi. so i guess i will be trying the home depot regulator.
GEN3Typhoon
A bit off topic here by to you problem of popping IC hose connections.. have someone weld a small bead in two places on the lip of the pipe.. I usually weld like a 1" long bead 180 degrees from each other.. then when you tighten the clamp down.. it cannot come off because it is behind that bead.
I have never blow a hose off with this done.
Just my $0.02 for you.
cvcsmkr
will the stiffer spring help it. where do i get the spring any size or anything i should know about. do you know how it will compare with that home depot regulator?
cvcsmkr
duuhh i for got boostvlave had their own site, i bought from turbotime. i will try that washer trick and maybe it will put me right where i need to be. thanks
Ian Turgeon
Cascading Inspiration
i used that valve as is with my progate and boost was inconsistent and unrelyable. I dont know what the reason is, but when I switched to the depot regulator that we were using on adam's pro gate, all was good again.
Leads me to believe they are better suited for integral gates. Why however, I dont know.
ghettosled
SYTY SUPERSTORE
Innovative offers a 5 and 10psi spring for the minigate. If you want base boost run a single line from the compressor housing or manifold straight to the side of the wg.. leave the top open. the more pressure you apply to the top the more boost it makes.
Contrary to an internal wastegate, you will want the bleeder opened more for higher boost on an external. Internal is the opposite.
nightdiver
exhaust back pressure helps open the external earlier....so you know you got a small turbine :wink: what turbo do you use ?
cvcsmkr
stock turbo
i tried the home depot regulator and it didn't work i tightened it all the way down and i was still making upwards of 18lbs.
so i put the boostvalve back on. i added a small washer to shim it. and it seems to be holding about 13lbs good. so i will open it up a little and try to get some more boost
ghettosled
SYTY SUPERSTORE
did you ever determine what the base boost pressure was (completely removing any boost controller), and just applying manifold pressure to the side.
DanenGraham
Big in the rear
I am still having boost control Problems with mine. Not really sure why???
It will spool really fast up to 10 then slow down but will make it up to 20+ if i dont let off.
(only running base boost line mind you)
cvcsmkr
you have mini-gate, what size spring. if your actually running base boost
then you have some problems, i would check the vacuum lines to wastegate. how does yours vent?
