Hi all,
I recently installed my TIAL wastegate on the sy. I must say it sounds mean
8) when you punch it it goes like :evilbat: and everyone else goes
. I must say that the overboost problem was gone and now I get rock solid boost
8) ::thumbsup:: ::brews::
nfire: .
Oh, I almost forgot :wink: . When I was installing the gate "I THINK" my truck has something different. when I was looking for the vac lines(before I started working) I found that the solenoid vac lines where disconected and the turbo's vac line was connected to a vac. T. I then started following the stock wastegate's vac line and it was headed inside the cab. I looked at the "knob" under the steering wheel which I thought it was "stock" and It looks(Don't want to say that it is indeed) a craftsman air regulator :-? ??? Well I kept the regulator that I bought inside it's box and tried the one I had incab and It works great
I would like to know if I have some kind of custom work in the truck or if that it's normal or why they would use an air regulator for the stock wastegate??? I had always tried to use it to decrease PSI, but it didn't do anything different with the stock gate.
