Re: Installing an msd distributor tomorrow. Any tips or hints?
Before you do anything, be sure to scribe or paint marks on the lower intake and firewall to note the position of the distributor housing and rotor, precisely. If you do this and also draw it out on a piece of paper, take digipics, etc. you'll have a much easier time installing the new MSD and you'll have piece-of-mind knowing it's installed correctly Do NOT turn the motor over while the distributor is out or you'll have to do a mechanical timing check with a piston stop and start from scratch.
When removing and installing the distributor, grab the rotor and turn it counterclockwise while you wiggle the distributor and it will work its way out. Installing is the reverse, but you'll turn the rotor clockwise. Mark the plug wires too so you know which wire goes where when reconnecting. After installing, disconnect the tan wire under the passenger side carpet and verify timing with a timing light. Should be at 0 BTDC, as indicated by the recessed notch/groove on your damper, assuming it hasn't slipped (mine hasn't in 70K miles). Good luck, I have the MSD Pro Billet #8367 unit and it kicks ass!
