installing cam bearings...what size order???
Syclone#2960
What ever it takes!!
Rebuilding my old motor for the 1st time.
I have a set of clevite cam bearings that are marked:
1. sh1349 -1/05
2. sh1351 - 8/04
3 sh1350 - 7/04
4. sh1349 -1/05
Is this the correct size order on the block???
TIA
warmpancakes
Re: installing cam bearings...what size order???
you have a rebuilt or later model motor the second numbers are the date stampings
1madgumby
Im guessing the 4 didgit # is the size, I would get A micrometer & make sure you get them in the right order.
Syclone#2960
Are these the new bearings or the ones you removed?
Justin these are new clevite bearings I got from RPM. Just don't know which goes where. The existing/worn ones are questionable to reference cause the #4 cam journal only had one oil hole passage and it should of had two like the # 1 did.
Norm
When the blocks are machined they are drilled halfway through, coming in from the front, then the process is repeated from the back.Call a machine shop and se if they will tell you the right process. Who took apart the old ones?
Syclone#2960
I removed the old ones.
The new ones were numbered (1-4) in that order with a sharpie. I'm going to install them like that. I think Mike at RPM should be able to answer this question.
