Installing Distributor
Lynn D. Brown
Hey Guys,
Just primed my engine and found leaks and fixed them.
Now I'm installing the MSD distributor which I had taken out. Always when I put it in it hangs up the last 1/8-1/4". Will the bolt pull it all the way down ?
Larry
Sounds like the distributor is not engaging the oil pump. Don't use the bolt to pull it down. Just need to pull distributor back out and rotate the pump with a long screw driver until it lines up with the distributor, may take a couple tries. Larry.
Lynn D. Brown
Thanx, Larry,
It's kinda tricky, like everything else on these damned machines. It took me 4-5 times. That oil pump shaft is real sloppy and moves around alot in there.
The tightening bolt at the bottom of the distributor seems like it may be a little long, as I have to really tighten it hard - like maybe it's bottoming out or something. Maybe I should put a washer in there, however that means I will have to pulL everything apart again.
I have the Upper Manifold off now. It looks like it will be almost impossible to get at that bolt with it on. Is everyone using a special wrench - and where did U get it ?
I have the crank damper set on 0 Deg, and I set the distributor set so that one of the "feet" on the spinning rotor is in the middle of that blue pickup thing (magnetic ?). Hopefully that's close - does 1-2 Deg mean much on these engines ?
sytyguy
Moderated User
Lynn.......I started using studs on most of my distributor installs. This would keep the bolt from bottoming out.
I (as well as others I'm sure) use a special 9/16 distributor wrench (available anywhere). Works well for getting to the bolt when the topend is assembled.....however, with our fuel rail, it doesn't lend itself to the same range of movement as on other engines.
Also, if the distributor gear is meshed with the cam, then you can just get someone to bump the starter while you lightly apply pressure (downward) to the distrbutor body (watch for the rotor....it will be turning) and the pump shaft might slip in better. Then the disributor may plop down a little lower. I would hate to have to tighten the bolt to bring the dist base down.
Does the MSD require shimming? Other users may chime in and be able to answer this.
HTHs
Hood
Tim Zapoluch
Usually you can get the oil pump drive shaft to line up by turning the crank pully bolt with a breaker bar/socket, as this keeps the distributor in time with the cam. sometimes bumping the starter moves it too far too fast, but usually works well.
Tim
