installing lightning pump
ty166
does it matter which way the hoses are run to the lightning pump from the upper ?? also im havin a MAJOR brain fart , on the lightning pump does the positive and negative matter as far as which way i wire the plug..... man 12 years outta the field catches up fast and makes you feel real stupid at times.... tia
ty166
Re: installing lightning pump
came with a motorcraft connector, wires are the same color..... :(
ty166
wont have time tonight , and heading out fr the week in the morning... i will most definatly do what you suggest and post up results most likely next weekend.
ty166
ok here is what i figured out and hope im right,
i mounted my pump like this.
and wired it like this
then popured water down the hose like this
most definatly pumps better if i reverse the leads and make the positive the ground. so obviously mounted in this postion the top post needs to be the ground.
thanks for the help dave !!!
no time tonight but i will check the rotation next weekend.
