installing oil psi. guage?
sy#2921
BAMF
Re: installing oil psi. guage?
If you are using the port on the oil filter for the turbo feed then you can use the stock location for the oil feed down on the block for your gauge
1madgumby
Now if I unplug the wiring harness will it mess with the ECM? If not I don't care if the stock guage don't work.
bezerk
i believe you can do that, but 1)it's hard to get at 2) if the ecm reads 0 oilpressure it will shut down the spark, (not sure of that) but why wouldn't you just T the turbo line?
