Instrument cluster wiring
Elder Dragon
Does anyone have an instrument cluster wiring diagram?
Or more specifically, does anyone know what sort of signal is needed to drive the stock boost gauge?
Thanks.
just a 6
R.I.P MyClone
Re: Instrument cluster wiring
0-5 volt
Thanks.
V6 Kompressor
just a 6 said:
V6 Kompressor said:
That gauge signal is generated by a map sensor (2 bar). It's the same signal that goes to the pcm for press/vac.
Which is 0-5 volt
Which is correct... and I didn't want to infer differently.... sorry, I thinks I just used up all my $2 words for the week... I was under the impression that this guy wanted to hook up a sy/ty cluster in something that wasn't a sy/ty... a 1990's turbo-suntird uses the same cluster, basicly, except for the red-line on the tach and the color of the the "glow" on the instrumentation night lighting. And hell yes, the sun-tird is a 4-banger so the tach circuit is wrong.... so you can use a turbo suntird pin-out for a cluster in a pinch if you can't find a wiring diagram for a Sy/Ty. I know, the guy asks for a wiring diagram, and i give him a thanksgiving day speech... :drinking:
