Intake Exhaust Valve sizes
Tydriver
TurboLS6 Powa'
I am concerned more about what is compatible with overall length of these valves that fit a VORTEC HEAD.
I assume its standard GM valves for SBC stuff right ?
I looked and couldnt find a relevant post in search about what valves are compatible with vortec heads.
I realize exhaust valves can range from 1.5" and up, also that intake valves have been 1.94" and up.
This is NOT what I am CONCERNED ABOUT, I want to make sure i get something with the same overall length as stock vortec head valves so I know I wont be causing geometry issues. I intend to go back in with 1.6" rockers that are self aligning and I figuired I would consider a possible valve upgrade. I want to know what is the same in overall length, stem size etc.
myclone
Here is a pic of a Manley "pro flo" that is stock length which measures out to be 4.910". When I order valves for stock iron heads I order "standard length" since I dont know what the stock length is off the top of my head.
The only reason I know of to order longer than stock valves other than for raised runner heads is to get proper valve spring seat pressures with extreme lift cams. To splain it as short as possible if you are running lots of lift you may need a taller valve to get the correct spring hight and pressure without going into coil bind. Needless to say this requires custom push rods or lash caps to get the rocker arms in the correct location for proper travel across the tip of the valve.
So, if it was me and I was working on a stock iron headed build I get "standard length" (as Jegs calls them) valves in the head size I want. Ive never had any probs so far with doing this but I also check EVERY valve on EVERY cylinder to make sure everthing is lined up and of the correct position from minimum lift to max lift.
HTH
myclone
Heres a pic of a stock intake out of a 772 vortec head. It measures 4.882" which is .028" shorter.
This is .028" shorter than the manly but keep in mind that the stock valve has some miles on it and may be worn slightly on the end. Its prolly not worn .028" worth but Im sure its still a little shorter now than it was when new. So, keeping the wear in mind Id guess it would be closer to 4.885-4.890 which isnt enough to warrant an all out valve train re-engineering project.
Tydriver
TurboLS6 Powa'
Damn Myclone, U are the man. Exactly what I was looking for.... You dont happen to have a supplier for those valves that is selling them dirt cheap do ya ?
myclone
There are some deals on ebay under engine parts, valve train, etc.. Thats prolly the cheapest place I know of but of course you have the typical risks of getting cheapy off shore junk or whatever like 75% of the stuff on ebay is.
Captain Morgan
Moderated User
ok, so I remembered this post and surprisingly was able to find it again....
so here is my problem.
Im gonna be going with Manley valves, either the Severe Duty or the Pro-Flo. Now the problem of valve length comes into question again, are both intake and exhaust valves the same length??
Reason I ask is because both intake valves, stock length, pro-flo #11830 and SD #11596 have a length of 4.911" which matches perfectly with what Dave posted above.
NOW, the exhaust valves are different story, as there are 2 SD valves to choose from but only 1 pro flo.
SD #11543 Length: 4.911 in
SD #11595 Length: 4.936 in.
Pro #11827 Length: 4.936 in.
so now what gives?? are they supposed to be the same length? I thought they were. Dave, you have the Pro-Flos, is there a 4.911" ext valve?
sorry if this seems like a stupid post, but this is the best thread I found reguarding my questions and it answered them all but this one.
oh yeah, this is for L35 heads as well.
anyone know the answer?
myclone
Ive got a full set of Pro Flows in the garage and I'll measurean exh for ya tomorrow (well, later today for you non-night shifter ppl :wink: ). Off the top of my head I think they are the same length.
Captain Morgan
Moderated User
thanks dave, i really appreciate it. I just dont wanna go ordering the wrong stuff.
also, i went and checked manleys newest online catalog, no PT # for a 4.911" ext valve in the Pro-Flo series :(
myclone
Sorry I didnt get to the measurements til now but Ive been fixing/chasing a vibration in the dually (ever wore out U bolts just from taking a rear diff in/out so much?).
Anyway, the measurement on the Manley exh valve length is 4.9090" and I measured it using the same mics that the int valve was measured with (I calibrated them with a standard before each measurment too FWIW). This gives us a difference of .0001" which IMO more than qualifies as "fudge factor" since Im holding the valve and mic free hand. So, IMO the valves are the same length.
FWIW here is the Manley part # of the Race Flo valves:
2.02" Intake with 11/32" stem 11566
1.60" Exhaust with 11/32" stem 11565
HTH
Captain Morgan
Moderated User
HTH
ahhhhh, so they are the Race Flo, not the Pro Flo, that solves that mystery :D
thanks again Dave. I'm not sure if I wanna go with the Race Flo's or of I should go with the Pro Flo's and shim up the .025 difference :-? hummmmmm, decisions. I dont think I want the Severe Duty's anymore at least so I can cross them off the list.
myclone
Hmmm.. Looks like I got my terms mixed up.. I was typing/thinking pro flos when I actually have Race Flos. Sorry :oops: .
FWIW.. Ive used race flows for a BUNCHA different applications and never had a problem with them. Some ppl dont care for the reduced stem behind the head of the valve but Ive never had one fail even at 8k+ rpm while in valve float on numerous occasions (long story). Even with our elevated exh temps I dont see any issues as 99.9% of use stay WOT for very short periods of time. If you were building a high rpm race only or turbo salt flats motor then the SD valves would be extra insurance IMO due to the extended periods at WOT (which would = high stress on the valve).
FWIW II... The only thing I can see that would be an issue with using the longer valves would be possibly needing longer (read possibly custom) pushrods to make sure the rocker to valve tip geometry is correct. If it were me and I did the Pro Flos Id mock up one cyl head, the cam, etc and check the rocker tip to valve stem tip geometry to see what it looked like. Shimming the springs to get the seat pressure you want is a no brainer but ya gotta make sure the rocker tip is riding where it should on the valve tip all the way from min lift to max lift. If its not then longer push rods are needed (or if the geometry dictates shorter pushrods you can use lash caps).
HTH and sorry about the mix up on what valves I had on the shelf...(yeeesh, how embarrassing :oops: :oops: )
Captain Morgan
Moderated User
Dont sweat it dude. I just looked back on this thread to double check the valve length (which I got, thank you) and I just happen to notice that you mentioned the "Pro Flo". :)
I understand what your saying about the valve length, I guess its something I will have to think about more.
As far as the strength and durablity of the valves, im not even sure why im so worried about it, i mean ANYTHING aftermarket has got to be better than stock.
I'll probably make a new thread and post my complete engine parts list that I plan on using once I get it complete and let everyone nit-pick what I should and shouldnt use :roll: :lol:
I really only want to build a motor to break into the 11's but I also only want to do it once, so I would rather just do it right the first time.
Either way, thanks again for the help on two accounts and for clearing up the confusion.
Happy New Year!! :bday:
