Intake hoses/ K&N cone
willyson
trollin'
When replacing the stock air intake box with a cone leaning towards where the battery is located, is the orange hose going to be damaged by the line coming from the radiator (i.e. will this hose get hot enough to burn thru)? also, the hoses leading into the stock setup need to be capped? this gonna affect anything serious?
12secondSY
Syty Killer :(
Re: Intake hoses/ K&N cone
It shouldnt burn through, if it does then your trans fluid is way too hot and you have another problem.
The lines going to the stock tube is for your pcv system. You could just put breathers on the valve covers but they can make an oily mess.
willyson
trollin'
what is the best option for these hoses? should i route them somewhere where they can get filtered air, leave them open, or plug them? thanks for the post.
12secondSY
Syty Killer :(
It would be best if they were back in the intake somewhere because the air rushing by helps pull the gases from your crankcase.
