Integrating DM and WB
sy1907
SYCOTIC
Us northerners are having trouble getting our PLX to interface with DM. We're trying to get it so we can read the WB on DM. I think some people have done it tapping into the stock 02 wires, but can't remember. Anyone have any luck with this?
leroy
You need to run the wb output to pin f14 on your ecm. Then you need a code patch. The diy-wb code patch will work, but use the egr duty cycle to figure your a/f ratio. There should be more in the archives if you search.
Jim
sy1907
SYCOTIC
Jim, we tapped into f14 and grounded at the ecm to avoid goofy outputs. We were looking at AFR tgt on DM and it was off by a factor of 2 or 3. When i get the WB hooked up later this week, i'll check EGR DC. The only problem is we have deleted the EGR valve, will this cause a problem for your method? And yes, we're using a code patch developed by Dig.
leroy
Deleting the EGR valve is good. EGR duty cycle uses percent as the unit. You need to convert that to get the actual a/f ratio, but they are all just numbers anyway.
Remember:
0 volts = 0% egr duty cycle= ~10:1 a/f ratio
5 volts = 100% egr duty cycle = 20:1 a/f ratio.
The plx output is linear, so other a/f ratios can be determined with some simple algebra. Dig posted something awhile back about this, and he included a conversion table in his post.
This method has greater resolution than using the AFR target field. Dig's original wb patch would have even greater resolution, IIRC.
HTH,
Jim
