Hey Scrapn,
- Cobalt 3/4" elbows SS... GM part #22707607.... $18 each - three is best, two work
- 3/4" braided SS heater hose from Summit Racing (SPE-39710) .....$29.95 per 10 feet section - two needed
- Derale 7" fan from Summit (DER-16507) $69.88 - one used
- Pump is from ZZ performance - only pulls 2 amps and flows a LOT of water - it's the factory supercharged Cobalt pump - about $110. The pumps from the vendors here on the site work just as well, are a lot less expensive, but draw a little more current - I'm concerned about current cuz I'm also going to add a tranny cooler with a second Derale fan back under the bed.
The hose couplers are Gates items that NAPA keeps in stock.... about $2 each.
Get the 'good' stainless hose clamps that are used for sprinkler systems - very strong and they NEVER rust.
Don't buy the fancy AN-looking fake hose fittings - they don't let the hose slip over the barbs on the IC inlet/outlet, and are so big they look kind of dumb.
My intake temps run 10-20 degrees above ambient regardless of engine temp or length of time running. I'm just running premixed antifreeze right now, but will probably switch to distilled water and water wetter since I don't have to worry about the IC or parts freezing during winter.
Hope this helps
....Rob
