Intercooler Pump Relay
TYHOGG
Since i have switched over to a/a, is it possible to delete the old relay? Any wires i should pay special attention to? I was just going to cap the positive 12v, and gut the rest. Any one have any suggestions?
TYTILIDIE
METH HEAD
Re: Intercooler Pump Relay
I just deleted mine. I have the entire harness out of the truck though. I would say unless you are really really bored to just leave it alone. The thick re wire goes all the way to the alternator, the pink and black wire is a switched wire from the ECM, the orange wire runs to the IC pump and the yellow wire is the signal wire from the ECM. If you don't want to pull it all apart I say leave it be. If you decide you wnat to pull it all apart then you have issues, like me:lol:
TYTILIDIE
METH HEAD
Yes, it is switched, but not by the ECM. It is switched on by the ignition switch. This is a power feed. Hot in run and start. Comes from the 'ECM A or 1' fuse. It is one side of the relay coil. The other side is the yellow to the ECM.
Interesting, I must have a different harness than the rest of the SYTY's. No matter where it ends up, mine goes in to the ECM. From a physical point of view. The wire actually goes in to the ECM. Where it goes after that is probably what you are saying but from the relay, mine goes IN to the ECM. Of course it also branched off to the fuse box but it still goes to the ECM. My point is only that to remove it "properly" there is a lot more involved (IMO) than just capping wires off.
TYTILIDIE
METH HEAD
No you don't. All SyTy harness are like yours. some replacement harness are different in this area.
Yes, the above is correct. I'm not bagging on you, Mike, I'm trying to help you understand a subject (wiring) that I'm light-years ahead of you on. Here's a test:
What is the purpose of this pink/black wire that goes to the ECM???
Hint: Remove it, and your truck won't run. Why?
Hint #2: Read this post again very carefully.
Regards,
Dave
Damn Dave you are such a dick sometimes. I have always tried to be nice to you but you always come across as such an ass. :lol: I am not saying you are wrong, for the second time I simply stated that that wire does run to the ECM. YOU should read what I wrote. Based off of my notes, the pink and black striped wiring seems to me it is used as a "tickler" for some of the relays. If I am wrong I am SO SORRY DAVE. My point still remains, don't cut all the wires unless willing to go a lot further.
