Re: intercooler pumps
Everyone here says go with the johnson or Shur-flo. which is about 2.8 gallons Per Min. but after reading a few books on turbocharging, Maximum boost by corky bell, Turbocharging (old book) and one on super, nitrous, and turbocharging, they all say the same 3 things. an Air/Water NEEDS a resivour, it's not an option to not have it, best yet it will hold enough so the water only makes one pass in 15 seconds. the CCHE is the LEAST important part, and 1 Sq. Ft is more than sufficiant. the larger the resivour the less important the CCHE. and the I/C pump should be a MINIMUM of 10gpm. (one hell of a far cry from the Shur-flo). Basicly a porperly setup Air/water is far superior to an air to air in every respect except if your doing endurance racing. water will conduct 14x the heat from the IC than air will, and a Water IC is working imediatly, air/air doesn't do chit till your up to 40mph at least. and straight water is best, add just enough antifreeze to keep it from freezing, or be sure to drain it before it freezes/winter storage.
I picked up a 4 gallon fuel cell from summit for 90 bucks (went kinda large, was the smallest they had, want to be able to pour a bag of ice straight into it), a 750 GPH (12.5GPM) bilge pump from a marina for 40 bucks, and some hose/fittings for another 30 bucks, it's going in today i'll let ya know my results later tonight :tup:
