Speed Mafia
I am new with the whole typhoon crew and last night i got a wild hair to start taking the truck apart!
So i pulled the K&N and it had 2 hoses running from the valve covers (both sides) to the piping on the K&N intake for the turbo (i assume to pull pressure from the crank case and help rings seal little better during boost). all the piping was covered in oil (cleaning pips and K&N tonight) I think that is normal but if there is a little mod trick someone chime in...
So i pulled the cheesy rubber pipe from the Volute on the turbo to the IC (had a whole in it i need to replace) and if someone knows of a part number or piping that looks clean please post from turbo to IC....
Then i took the intercooler off and i was wondering how hard it would be to run a front mount Air/Air and take off this system? Also on the intercooler stock setup i cannot find a mod trick on that i know you can have something start up earlier but i cannot find a link on how to get the pump going at startup etc...
please chime in and give this newby some advice!
