Re: Interested in the 50 lb injector setup, HELP ---
Did you your IC pump working and get datamaster on your truck yet? You should find out how your truck is running stock before installing any chip. Do you have a 255 fuel pump yet? A stock fuel pump might not be able to keep up with the raised fuel pressure, and with no IC, I kind of doubt it will break anything in your engine, but I wouldn’t be too surprised if it did. Running lean is running hot, no IC is running hot, running hot causes knock, knock breaks things.
I tried to explain alcohol injection in the 104+ thread, did what I said make any sense? I’m sure since Mike is selling the spearco kit that it is a good kit, I would just make sure that it is progressive and that you can run 100% alcohol with it.
Get your truck running good stock, then add the chip and make sure it runs good that way, then add the alcohol. Don’t try to use performance modifications to make up for less then optimal tuning of the stock setup. You said you want to run 13s the first time at the track. A stock truck that doesn’t have any problems will do this pretty easily. Sorry if I sound like I’m preaching, you just seem a little too eager and I don’t want to see you break a piston or anything.
