interesting idle at high rpms
doomdead
I got my fuel pump fixed, at idle i run at about 40 lbs of fuel, little throttle brings it up to 50, and when i have it floored it goes up around 60.... im still running stock injectors... around 13-14lbs of boost.... if i put it to about 80% thottle it accelerates very quickly no probs, but when i go 100% throttle, at around 3,500-4,500 rpms my needs shakes... isn't too sure where it wants to be...
too much fuel for the stock injectors/chip ???
seomthing wrong with my new plugs and wires??
if you guys need a DM ill get one asap...
thanks
Rob
oh also, while i remember, i have some sort of knocking thumping sound coming from what seems like the lower rear of the engine... only a guess, no one knows what it is, it doesn't show anything on datamaster... and only happens when its warmed up.... any thoughts?
Tooky
Serious about performance
Mine also makes a noise from that area, it sounds like a helicopter from inside the cab. My fuel pressure gauge seems to bounce in time with the noise but I have insulated my fuel lines so I don't think it's that. I have heard it could be my tranny lines contacting the cab, too damn hard to see in there to find out if that's the case. Anyway if you figure it out, please let me know as it drives me nuts sometimes.
smeagol
Your needles shake? As in tach? boost? fuel pressure gauge?
Your vibes - take out the propshaft, see if it changes. Otherwise, it's probably TCC related.
doomdead
rpm, boost is steady around 13-14lbs (it launches up to 15 for a sec but drops a little then holds) my fuel pressure sits right on 60.... and it seems like if i floor it, it doesn't want to give it all its got, yet when i go around 75-85% tps everything is nice and smooth.
only noticed it after i turned up the fuel pressure.... dunno why... remember i have stock injectors (where can i get some new ones) and stock chip...
rob
smeagol
From the FAQ- on the left side of your screen
My Tach keeps fluttering What causes this?
Telltale Ignition problems. Do tune up with the above listed products.
doomdead
use what??
and i have done a tune up, running stock plugs, accel wires 8.8, conrad cap and rotor, its timed to 0 degrees..... etc...
it happens only at high boost.
smeagol
If your tach is fluttering in boost, it is ignition.
Sorry, I don't care what you have done to the ignition, something is still wrong with it.
You have a cracked plug, a bad plug, a bad wire, a burnt wire, a plug boot that isn't all the way on, a cap/rotor not installed correctly, a plug gapped incorrectly, a bad coil, a bad connection to the coil or distributor, etc...
No way to fix it but to go through it all again. I'm not a fan of Accel ignition *anything* because of problems like you are seeing.
