so im doing a small build over the winter. nothing crazy just a street truck. id be shocked if it saw the track a couple times, if at all. ill be doing the basic vortec head swap, 415 cam, headers,bigger turbo, fuel system, ect. I figure while I have it out I may as well do forged pistons and rods, as well as a .030 bore so I know the walls are smooth and straight. my question is there is tons of bearings and ring options out there. ive been told get king bearings, ive always run them and had great luck but they are very inexpensive so I don't know if they aren't good enough for a stronger motor. as far as rings I have no idea, I get so much mixed info.
Do the eagle rods come with wrist pins, or the pistons? or are those separate ?
What is the recommended head gasket with the vortec heads? thanks guys
