Re: is a ty for me???
IMO Sycloen at some point and time during production were rated to 1000 lbs (other times it was 0 lbs). If I remember right, The " Who says a Syclone can't Tow" ad had a dirt bike on trailer. The major difference between a Sy and Ty in that regard in the Typhoon has air shocks and lower about 1". I personally think a Ty could tow with out much problem, especially if you watch the tongue weight of the trailer. I would put on a tranny cooler and watch the ride height. You will also need a custon trailer hitch as well.
As for makin it a daily driver, that is what Honda are for
Seriously they can be used be most often aren't recommended. You can search but they require more maintence than most vehicles. You will also find the gas mileage quite a shocking difference for what you already have, for the three year of production the were rate (14/17mpg, 15/19mpg and 14/18mpg) I have found I usually 13-14 around town with some boost and 19 on the highway is I am easy on the gas.
EngineNoO9 said:Anyways. I've been scoping out the idea of buying a typhoon late summer to use as a daily driver as well as a minor tow vehicle for my motorcycle (soon to be 2 bikes..). I've read all the threads that say well they aren't rated for it, the tranny will break, etc etc... My question is... I've seen talk that the 4L80E or a t-56 even will alleviate the issues with the tranny being the weakest link not only in normal driving but in towing applications. So... if I get a typhoon, drop a 4L80E in there and get a hitch on there.... will it be ok to tow say a max weight of 1000lbs (figure each bike is 400 + 100 lb trailer...) assuming I don't romp on it (I've towed stuff in my dad's suburban before and even with a big v8 you need to take it easy I know). Also the reliability issues with a typhoon with about 80k on the ticker... Aren't most issues linked back to the diff and the transmission (other then the obvious 13 yr old vehicle replacement parts that would be required).... Basically I'm looking for either a go ahead and get the typhoon or forget it and dare I say get a ford lightning instead (ick I hate to even think it..). I do understand that the typhoon isn't rugged and is basically a sports car with suv skin and needs to be treated as such... So yay or nay...
