Is It Possible To Do A Twin Ic
syclone1100
RUNNIN AND SELLIN
Is it possible to do a twin IC set-up :? on a Sy??? I tried looking threw the search but gave up after 30 pages...
Flyin Ryan
hated cuz he drives fords
Re: Is It Possible To Do A Twin Ic
I would think it is.. only because I know there was a vendor back in the day by the name of Tony Dequick who produced dual IC kits which many liked but the guy's business pratices lacked greatly.
Try doing a search for DeQuick or DeQiuck IC etc..
Daron
Are you talking about dual water to air systems similar to stock?
What would be your endgame? If it is to cool the charged air then why not a larger system like Waller is selling?
sytyguy
Moderated User
Are you thinking A2A fed into A2W? Air out of turbo goes to FMIC then to A2W IC then to engine so as to kill most of the heat with the A2A then extra cool it with the A2W? I assume this is your thinking (I saw you post about dual cooling in the large upper IC thread), but the added weight and packaging could make this a plumbing nightmare. Even more so, with the gains from alky/meth injection in conjunction with a primary form of cooling (A2A or A2W), you'd be hard pressed to get the charge much cooler.
Hood
syclone1100
RUNNIN AND SELLIN
Hood
Yeah this was what I was thinking mostly out of curiosity than anything to see if there was a significant change in preformance and if it was even possible plus i was looking for a way to keep the engine running cooler without having to run alky/meth on a consistant basis. what ever I can do to keep it cool when the temp on the street is 150+++ before I even step outside...
QUICK STORM
B.A.M.F. BMW Tech
you would have a bigger headache than you do now!
just get some spal fans for you A2A and run alky when you get into high boost
sytyguy
Moderated User
Any particular reason you wouldn't want to run alky/meth? Bang for buck, it's up there with any add-on IMO. Otherwise (if staying A2W), do the basic upgrades (pump, lines, scoop, fans, and possibly larger upper unit) and hope for the best.
Anything is possible, so I wouldn't discourage you from trying twin cooling, I just don't think the end result would justify the cost or means to make it work.
Hood
syclone1100
RUNNIN AND SELLIN
Hood
I will be running alky/meth as soon as get the $$$ to buy it, I was just tossing around ideas for daily driver purposes ya know, ta keep air temps down while just driving around town.. I thought it might be easy or possible to run my piping from my KB FMA2AIC to the one that Waller is putting out then use the alky for the high boost application... I thought the cooler the better, and I really wouldnt be adding any more piping all I would have to do is custome fab one pipe witch I have to do anyway...
