TYTILIDIE
METH HEAD
If you turn the key to "on", you cant hear the pump primimg but you can only hear it if you get right under the tank. It sounds wierd, kinda like turning over a motor with no compression. When you turn the key to crank the motor , I opended the shcrader valve and 0 gas came out. Also I keep popping "ELC" fuses. What the hell is this fuse? JER and I tylaked about it and he did a search and came up with electronic level control? Is this tied into the fuel pump somehow? Anywya, they pop with hte truck off and the whole harness isnt even hooked up, it has elec tape over the connnector. Any ideas?
Mike
Mike
