TYTILIDIE
METH HEAD
Ok , so I I think Ive got it all hooked up right. I basically hooked it up to run the WB in place of the stock o2. I also have it to where I can put the stock o2 back at anytime incase the WB goes bad. Soemone please tell me if I have it right.
red-12vsupply-tucked away til I get the patch and can run it
blue-heater ground-ground away from other grounds(grounded under ECM on the firewall)
white-system ground-I have this wire going to ECM pin B9
yellow-analog out 1-this I put in with the stock o2 wire(purple)
brown-analog out 2- this I have running to ECM pin F14
green-analog ground-is running to ground about a foot away from the blue heater ground
black-calibration wire-not using it since I have the XD-16
Is this right anyone?
