cwik1 said:
Currently stock with AC plugs, Accell wires, and Accel Cap'n Rotor.
I will be doing the following:
Top Dead Center
Conrad DR2012G
Taylor Wires (TAY-74632)
NGK UR6IX plugs
Vacuum Line replacement
maybe PCV valves
(starter just replaced with 10 gauge wire heat shield and wrap)
Gauges - Boost, Fuel Pressure, Trans Temp
Trans Cooler
(already have 160 thermo)
KB AFPR
IC line replace with heater hose
Jabsco IC pump wired always on
if running right after above and tuned
3 Bar and Ultimate Chip
(have stock airbox with KN Filter)
I am not familiar with suspension. My Ty drives pretty rough. Will greasing the suggested parts in the FAQ's fix this? What do I need to replace to get a comfortable but not too soft ride? I will be putting Baers on the front and would like to do the susp too.
Lastly any suggestions on where to get the truck painted in the Illinois/chicagoland area. During the schoolyear I can leave it at a shop since I don't bring it down to Champaign with me? I want to do the whole truck incl. cladding. Pricing?
Thanks
*cringes again as he reads the use of Accell products*
Suggestions for you:
First things first... you need to get your truck running good before you worry about going fast... forget the gauges, AFPR, and Ultimate for now...
Do GM Top engine cleaner FIRST!!!! "BEFORE" you install... the ignition components...
http://www.sytyarchives.com/howto/viewarticle.php?article_name=top_end_cleaner.php&dir=engine
Make sure to change your oil after TEC...
Next do a full tune up (Taylor wires, NGK UR5 plugs, Conrad cap/rotor, check timing)
check for any leaks of any kind...
Replace PCV valves..
check for vacuum leaks.. (Purchase Ian's kit if he has any left, nice product well worth it)
When's the last time you changed you tranny fluid or filter?? what's the condition of the fluid?? been over two years or 15,000 miles?? then at a minimum pull the tranny pan and inspect it or have it done... and replace the filter & fluid in the pan..
Add the transcooler and maybe a deep pan like the derale ..
When's the last time you replaced the Transfer Case fluid??? been 2 years ?? replace the fluid
When's the last time you flushed your radiator...?? been two years?? do it..
When's the last time you changed the IC fluid..>>> been two years? do it...
this can be done at the same time you reroute the IC lines with hose
Done everything above?????? Now consider purchasing a scan tool(Datamaster, laptop)....
I'm assuming your suspension is shot or very old?? ever replaced anything?? or have previous owners ever done so?? shocks?? steering components?? bushings are bound to worn out by now... might consider a polygraphite steering/suspension kit from PST ....
if you feel like it... purchase a suspension techniques sway bar.. it's worth it though...
finish that come back...
BTW: consider getting to know the Chi-Town peeps in your own Backyard... like green and max... maybe even BW (heard he eats small children).. wealth of knowledge in your area...
