Is there a vacuum line missing (pic)?
Pertti K
Should there be a vacuum line attached to this connector (left arrow in the pic)? There seems to be a small hole with threads in the face of the turbo (somewhere near the right arrow), that also looks like a good place for a vacuum hose :roll: And here's the pic
If there is a line missing is it unsafe to run the truck at all, even with less than 1/3 throttle? It seems it has been overboosting and cutting off the power with 1/2 to full throttle. Thank goodness for this forum, I might have blown the engine if I didn't start reading the posts trying to find out what's wrong with the truck :doh:
Thanks in advance! Could have sorted this out myself, but haven't got a service manual yet.
SY756
Re: Is there a vacuum line missing (pic)?
Looks like the vent port for the boost control solonoid. Kinda hard to tell. It looks like your solonoid placement has been altered. There is usually a "filter" over the port. If that's what it is then no, there is no vac line attached there. Oh yeah the threaded hole by the right arrow that's in the compressor housing doesn't go all the way through, pretty sure it's one of the mounting holes for the solonoid bracket.
Luke
Fish sticks SUCK !!!
hard to tell, but yes there should be a fitting in the compressor side of the turbo with a line on it going to the boost solenoid (single port side) then the on the other side, the bottom port should go to the wg actuator, the top port (with the little metal clip on it)is the exhaust port for the solenoid to bleed boost. as for overboosting that could be a completly different monster.(search overboost and see what happens)
Pertti K
OK thanks. I quess I need to check the wastegate adjustment next.
Edit: there is one vacuum line connected to the turbo on the left side of the lower arrow, but there is also another hole in the turbo just (or at least almost) like it.
SY756
I edited my post above on that.
Black Knight
I Glow Therefore I am
My bottom port has the metal clip and the top goes to the wg actuator, go figure?
Luke
it may not matter. hmmmmmm i wonder?
Andreas
If I remember correctly you only make 8psi without the boost solenoid unattached.
If your truck overboost now, you got a sticking or non working WG
Pertti K
Thanks for all the help and not pickin up on a newbie asking stupid questions... And here's a few more ;-)
Haven't had much time to dig in to this problem, but here's what I've found out so far. Unplugging the connector from the solenoid dropped the boost to 10 psi, so the WG and actuator are working properly - right? With the connector attached the stock boost gauge jumps to over 15 psi readings already with ½ throttle.
The WG rod seems to be bent, which shortens it. Maybe some earlier owner has been too lazy to take out the inner fender to adjust it properly. I haven't cheked the adjustment (should be 7/8 hole/pin overlapping in the connection as I've read), but I will as soon as I have the time.
So the questions are: Considering the symphtons is it possible that
1) the missing filter from the WG solenoid restricts the air flow so that now w/o the filter it's letting the pressure out too easily? Then the WG actuator would "see" lower pressure than it should.
2) this is a chip related matter? Haven't checked which chip mine has, but I will.
And one more: where to get those solenoid filters shipped overseas (Finland?)
Thanks again for your help!
Black Knight
If your unplugging the solenoid and getting 10 psi then you need to loosen your wastegate rod till your at 8 psi ( base boost )
If your overboosting at 1/2 throttle then might still have the vacuum llines hooked up wrong, here's how mine are routed and its always worked for me. As you see on the right the bottom port on mine is the vent.
The rod is a little bent from the factory to go around the turbo, atleast mine is.
1.) Don't worry about the filter it's nothing, they all fall off.
Hope this gave you what you need,
Roy
Epstyphoon303
1992 Typhoon #2019
Ok I know this post is super old but I had a ? About the pics that black knight posted. My lines from the WG solenoid are stock. It looks like ones in the picture are different. Is there a differance in how the waste gate opens with the vacuum set up like that? My line to the WG has a boot and looks like a hard line to the WG then another boot. Once again im new and still learning bout our trucks. thanks
Epstyphoon303
1992 Typhoon #2019
Sorry guys that last part was confusing.. The line from the solenoid to the WG is a small hard line with a boot on each end!
TNPhoon
1of28
Might as well spend the $ and just get a silicone vac kit.
My vac lines were so brittle they literally crumbled as I took them off.
My assumption would be that unless your lines on there are in perfect condition now, it would make a difference, if at minimal a reliability upgrade.
