Is there any difference between c6 calipers and c5 z06
littleblackpsycho
Re: Is there any difference between c6 calipers and c5 z06
I flippen hope so I just ordered them. From what I could find (which wasn't a lot) they are more rigid that's why I asked I assumed it meant thicker but it sounds like they are the same size and same mounting as c5 z06.
Fitos
base model are identical other than that they are different
It's just a six
Super Member
So the C6 z06 & the C5 z06 calipers have the same bolt pattern, same dimensions?
Just the C6 z06 calipers are 6 piston, correct?
littleblackpsycho
No not the c6 z06 they won't fit just the base c6. I think off hand the c6 z06 are the same as the ctsv but I might be wrong.
littleblackpsycho
Ok now you have me thinking tho. I know this would probably screw up the bias with abs but as long as you did the abs delete could you run either another set of front dual pistons on the back? Or maybe you could fit the c6 z06 4 piston rears all the way around?
If they would work that would be:
Base: 2557.45 sq mm for the dual piston
C6 z06: 2827.43 sq mm for the 4 piston
Over the 1359.18 sq mm for the single piston
littleblackpsycho
Will do but I'm in North Dakota for two more weeks so will hopefully be waiting for me when I get home.
