Is this the right long block????
92Phoon
I have a 92 Typhoon Vin Z, Chevrolet gave me this part number for a remanufactured long block. 12361247 Is this the right motor for my Typhoon? Thanks
sytyguy
Moderated User
1215321 is the current "correct" part number for the ZR9/Z79 engine. 12361247 is a stock LB4 engine - a la stock S10/Sonoma, etc.....
If you get a new longblock (1215321) from GM, you will (in all likelihood) get the following incorrect parts:
- grey iron main caps instead of nodular iron main caps
- stock head gaskets instead of the SyTy specific ones
- later model heads (not a bad thing)
When I was preparing to wage war on GM many years ago over my engine, I found out all of this. Actually, it seems around 1999-2000 most replacement engines were hit/miss and anything afterwards is most likely 100% wrong. They do seem to be fitting them with the correct hypereutectic pistons, but thats probably only because it's a production piece beyond SyTys. For the money it costs to buy a new longblock (~$2300), just find a spare LB4 block from any donor S10 and have it built with forged pistons and the correct main caps. This will give you an engine better suited than a stocker and will cost half as much to build. If you have eventual plans of going fast with reliability, go ahead and upgrade rods, heads, etc.... No reason why you can't come out cheaper than $2300 even with having to buy everything.
HTHs
Hood
tnsyty
I bought a GM long block back in 2000. I have been to the KC Nationals and the Great Bend nationals on it from TN. I have only put about 15000 miles on it though. Have been running 18-19 psi all the time. Diacom shows little-to-no knock. I have upgraded the turbo to a 20G. Still no problems with the engine. I hope i do not have any either. It is finally out of the 3 year warranty. My engine was $2300. They sold it at cost plus 10% Also when i bought mine they claimed they could only locate 3 more of them in the US. Don't know how true that was, but they have been a great dealership to me. Buy all my s-series stuff through them. Get better deals than buy Autozone crap alot of times.
bezerk
To bad, i have to do something with the Engine also .
But are you claming(please correct me if i ''am wrong) i could buy new block, forged pistons, H-Eagle beams, crankshaft ,rockers,oilpump, lifters, waterpump, gasgets etc.etc Without heads, manifolds etc, for about 2300 dollar??
please tell me this is right!
Need to build new engine, or go for an extreme proofe wich will give me a change to have to pull the engine 3 times in 600Miles :roll:
Info please
Rene
sytyguy
Moderated User
Unfortunately that's not what I'm saying. The $2300 figure was just for an engine from GM and I wouldn't even bother with trying to get a "NEW" engine and build it. I would look more for a used longblock that can be bored to .030 or something acceptable. Look to spend around $300-400 for a useable engine unless you just get you old one rebuilt (this would save a good portion). Then you have machine work, additional parts, etc..... Here's a makeshift breakdown:
- Useable engine - ~$300
- Eagle Rods - ~$350
- TRW Pistons - ~$250
- Rings - ~$30
- Gaskets - ~$200
- Bearings - ~$50
- Timing Set - ~$50
- Machine work - ~$300
This would constitute a pretty basic rebuild. You could opt to go "all-out" and buy a camshaft, valvetrain, a set of Vortec cylinder heads, etc...., but the above build would get you going.
HTHs
Michael
bezerk
So this maybe verry veryy stupid to ask but: what is the differantce between a longblock and just the origanal block??
my engine is new, but somebody srewed up with the mainbearings (one rotated itselve leaving alittlebit material damgage onto the housing of that bearing ).
But thanks for the information.
Rene
sytyguy
Moderated User
Shortblock - engine block, rotating assembly, timing set, and camshaft
Longblock - shortblock plus heads and valvetrain
A longblock is typically understood to be "the engine" but minus accessories, intakes, ex. manifolds, etc....
If your original engine can be salveged, by all means, use it. If not, look to spend around $300 for a useable engine from a donor truck. The good thing about your original engine is the heads, cam, etc..... are all probably reusable. So, in the "just to get it going" scenario, you would be in good standing (financially) if you just fixed the problem, upgraded a few internals, and got it back on the road.
HTHs
Michael
bezerk
So that makes it quite simpel.
i would really like to reuse my new engine, but somehow my main crankshaft bearing got rotated in the engine scraping some of the block material away,
so the clearance would possible be to big.
although, when you look from it from above, oneside of the oil-channel looks really good , at the otherside you could see just some scratches, talking about the block part.
i hope you understand my story.
bezerk
So how much do you have to pay for a Longblock in the U.S?
Went to the workshop and asked them how much a longblock would costs.
50000 Miles or 3 years warranty.
sytyguy
Moderated User
Well, since your heads, etc.... can be salveged, I would look for a shortblock. For a bare one in rebuildable condition I would spend no more than $75-100. They're just too common to spend any more IMO. If you would rather just get a longblock, I'd spend no more than $250-300 for an LB4 setup (maybe $400-500 for a Vortec longblock).
HTHs
Michael
