ISO: Stock L35 rocker studs
SYO237
SyTy Registry
I know most upgrade and drill to 3/8th, so if you have the stock studs laying around you want to get rid of, hit me up.
Be interested in the stock rockers too actually.....
wildphil
I Love My Ty's
Re: ISO: Stock L35 rocPker studs
Sorry I don't have any stock screw in studs.
ARP makes Studs that screw into the heads I think L35 heads are M10. Good thing about these studs is they are 3/8" on the rocker side. Easier to get rockers. But if you decide to use roller rockers you may have to use spacers or washers underneath the studs. If you are using stamped no problem.
https://www.summitracing.com/parts/arp-100-7201/reviews/
Loeryder
Sounds familiar.
This is why i went with the ARP studs. So i could use the Comp 1.6 rollers I already had.
I did find I could not use poly-locks and also had to run the washer under the ARP studs to get the height i needed.
I have a set of stock M10 rocker studs for Adam that I might send him someday... maybe.
wildphil
I Love My Ty's
Sounds familiar.
I used the APR studs also. I found a cheap set of guide plates and trimmed the guides off. So I could raise them enough to install the poly-locks.
