ISS and TPS adjustmetnt?
RSpengler
Ghetto Fab Specialist.
Has anybody had to adjust their Idle Speed Screw and TPS after installing Ported heads and or a Cam? I was told it doesnt matter that much on a Speed Density system, but Im still at a loss as to why my truck wont idle...
Thanks,
Rob
leroy
Re: ISS and TPS adjustmetnt?
You could try a little more fuel pressure. I'm guessing you are moving more air, but injecting the same amount of fuel. If the idle needs to be raised, it should be done in the chip.
There is no TPS adjustment.
The idle stop screw should only be adjusted to get the IAC counts to an acceptable range.
Jim
