etriebe
Rebuilt my engine and installed it with rockford racecrafts poly mounts and frame pads. I installed the engine first without the spacers from the the mount package and the engine went in fine this time, no problems now until i went to turn the steering wheel and the shaft hits my headers. I called it day and went back out this morning and installed the spacers and the shaft still hits my headers, I said f*** it for now and moved on to put my crossover on and the pass side hits the frame. last time i installed the engine I did not have any of these problems. If I pull the motor all the way up with my cherry picker with the through bolts in the mounts the shaft doesn't hit the headers anymore and i think i can get the crossover to bolt on. Is it ok to tighten the through bolts so it stays up or is there another way i can sit the motor down all the way?
