i finally have all the parts i needed, and everything is assembled. before i start tearing into the truck with the tools, i gots a few questions.
1. what pin on the ECM is the right one to use for the mv out put from the DIY-WB (search is givin me error messages)
2. as far as power and grounds go, is there a preference for hook up?
3. if there isnt a wire in the correct pin input to the ECM, should i take the ECM apart to install some sort of quick connect on the side of the ECM so the sensor can be pluged in quickly like the other wiring harnesseses?
4. if i do install a new connector on the side of the ECM for the sensor input........ whats to keep me from using a 3 wire plug and connecting power and ground inside the ECM as well? i could just put the 5a fuse inside, accessible at the MEMCAL opening? will the ECM ignition circuit take an additional 5a load on the backside of the pin inputs?
e
e
