blacktyaffair
Well sy-1177 needed new motor mounts and it didn't have solid mounts like I was told it did.
So I decided to give JTR mounts a try because I was being cheap. I hope $85 shipped mounts hold up! The truck does not currently have the lower half of the fan shroud. I will install one tomorrow to check fan clearance. Fan does not hit the top half of the shroud and I'm pretty sure it won't hit the bottom shroud either. For info on the motor mounts go here --->http://www.jagsthatrun.com/Pages/Parts_S10-43-2wdRepacementMounts.htm
Observe the Syclone in its natural habitat, on jackstands. I didn't take long, did it? At least I had help from my little sytyer.
Left mount.
Bolts that came with mounts were too long and would hit the left manifold. So I used the original bolt but still had to grind the pointy tip off so it wouldn't hit the manifold. It's close but it should be okay. I'll keep an eye on it.
Right mount.
Right mount heat shield.
Right mount manifold clearance.
I was able to reuse the heat shields but the driverside heat shield had to be trimmed. I like that the rubber pads are now bolted to the frame and not the block. They are a bit further away from the exhaust manifolds than the original set up. Also, the rubber will never deform and cover up the bolts like the originals. :tup:
I hope this is helpful to someone.
Left mount.
Right mount.
