jeep steering shaft warning
berzerker
wookie
This is to make members aware that i recently had an used jeep steering shaft fail on me while driving .
The shaft i had on my truck had the rubber isolater coupler located just below the upper knuckle / yoke .
the coupler is what failed and i lost steering , thankfully not complety until i got the truck slowed and stopped . It did give me a warning just a few minutes before coming apart , it felt like the steering gearbox went sloppy , then seemed like something in the gearbox / wormgear stripped . If you already have this style shaft on your truck i suggest removing it and atleast joining the coupler by drilling thru it at installing an 3/8'' bolt and locknut , and or weld bolt and nut to add safety factor .
Foot Performance
Re: jeep steering shaft warning
All the jeep shaft I have seen use 2 ujoints not a rubber coupler most of the stock shafts have rubber couplers
Got pics?
fauXGT
Brick Pilot
Yea, just the u-joints on a sliding shaft in the middle. Don't remember any rubber couplings.
SY2932
Administrator
Sounds like you have the Jeep steering shaft that was behind door number two. Prolly 98% of the people on here who have a Jeep steering shaft, myself included, have the one that is pictured at the top:
The one on the bottom looks like a fancier version of the stock rag joint to me which is why I got rid of it in the first place.
denny
I had a similar problem wiht the the jeep steering shaft I bought on the fourms here, here are some old pic. I end up drilling a hold and place a big nail thru it.
see the white mark
see it moved
TYTILIDIE
METH HEAD
I have the one in the top pic too. Problem I had was that it started to bind up when ever it felt like it. Once I was making a left hand turn and it got stuck and I almost hit the car in the turn lane. Then if I drive down the highway there be something of a "notch" when trying to drive straight. I don't have a problem with the overall design of the shaft I just think people should stay away from the junk yard units. (no offense to anyone who sells them) and buy a new one. Its not worth your life, or someone elses to save $50. I mean last I checked you could get a new one for like $100 or something like that. Yeah sure I can get one at the junk yard for $10 and 10 minutes worth of work but again, is it worth a life?
I removed my jeep shaft and went back to the stock one because the jeep shaft has a small amount of play in the slider section and I didn't like that.
Norm
Borgeson joints and you won't have any problems. Why put in used junk. I bought a jeep shaft and had the same problem. I figured is a couple hundred dollars worth smashing up my ride?
berzerker
wookie
yes the one in denny's pic is the style i had . was taken from an late eighties cheerokee . and i'm in no way stating not to purchase jeep shafts and using them , i will be finding the style with just the two joints and yokes and will feel just fine using them , i'm just trying to make members aware of this issue . jeep must have known there was an issue and at some time,, issued a recall / safety bulletin on these cheerokees and replaced the sahfts with the better style that are in the other pics .
