JESEL Shaft Mount Rocker Problem
TYTILIDIE
METH HEAD
Installed the Jesel shaft mount rockers by eye i.e., didn't use the tool and everything moved freely. I tried the different shims and the silver ones alone worked the best. Well, I haven't felt like I should move forward unless I pull a spring off of the valve and actually check it with the tool. So I took one off and installed the tool. I found I was just a smidge off, I had to add a thin black shim.
Now with the black shim, the engine does not rotate smoothly, it feels like its under compression and "springs" forward as I turn the crank, like the springs are stiffer or something. Would I be a fool to remove the black shims for the sake of rotation ease or is there a bigger problem here?
