I am leaning towards the timing chain jumped a tooth or so. After I get all the other little stuff fixed the ty still won't start. It has fuel and fuel presure, it has spark and it has air. When I crank it, it tries to start, maybe run for a second and die. I pull one of the plugs out to see if they are fouled, it is not. I turn the truck over it starts, sounds like it's running decent considering it has a empty hole. I put the plug back in, it won't start. I pull the plug back out it starts. I try it with the plug in the hole withoug the wire hooked up, still won't start. So, I change the plugs still nothing, I pull out another plug and it does the samething. I am thinking the chain jumped a tooth... Truck has about 12XXXX on it. Any help? I have not had a chance to check the timing yet.
