just got aldl cble and ?'s
Raist103
found this pic but when i plug mine in nothing happens??? if you look at the pic the aldl has silver tabs in each hole, mine does not. mine has it in a couple such as the one in the top right but not the second one in on the top. could this be why mine is not working? also i have datamaster, a p3 compaq and gpot the aldl cable from the gp. do i have to go in the back to make it work? and if so how does it come apart , is there 2 bolts or something? just want to be ready when i go out to play with it. mine also came with a cig lighter ext. do i need to plug this in or is it for older laptops?
SY2932
Administrator
A little unclear about what your ALDL plug looks like in your post but, it should look like this: http://www.sportmachines.com/maintenance/aldl.html My terminals are brass colored in my syclone. If you are missing the "B" terminal, you have problems. The "G" terminal is missing in my truck :-? .
The plug doesn't come apart. The terminals are held in place by the terminals themselves... Remove the two screws holding the ALDL plug to the bottom of the dash. If you look on the backside of the plug, you will see a small "channel" that you can insert a paperclip or jewler's screwdriver to depress the tab that holds the wire/terminal into the plug. Just gently pull the wire out while depressing the tab. But, if you are missing the "B" terminal, the tab that holds it in place may have broken and it is just laying freely behind the ALDL plug.
Sounds like you have one of the Datamaster cables that uses the ground in the cigarette lighter to ground it. The cable that I bought from Andrew M. didn't have one and it works... sometimes :-? . HTH's
Mike Campbell
SY2932
Administrator
I don't understand what you are asking... do you have a AOL IM handle? I keep getting a "the page could not be displayed" when I click on your profile...
Mike Campbell
Raist103
tried a bunch of things to get datamaster working and i got it to find the aldl cable but i am now getting a pcm or something like that error? anyone have any ideas?
ed hess
race or get outta the way
don
you need to set the serial comunnication speed to something around 195 in dm, open File, record aldl data, options, advanced, serial communication timing, aldl link timing, set this to 195. you may have to move up + or - 5, trying 1 at a time. this is is the help file for dm.
ed
Raist103
yup i did that but thatnks ed, hey maybe i could stop by if i get done work early eoungh one day and you could check mine out for me?
ed hess
sure, but what did you wanna check?
Hey monday arond 330 i think phoonrt was bringing his ty over to get it tinted. Come over then and if he's around we can all swap a lot of lies about how we all r un high 11's and lo 12's lol
ed
InvisiBill
You only need to plug the solid blue wire into the lower right hole. The blue/white wire is ground, and can be used from pin A to provide ground to the conversion circuit, or to provide ground to another pin in other cars (via the cigarette lighter plug's ground). http://syty.net/phpBB2/viewtopic.php?t=19751 has more info if you didn't see that...
